Install shim washers to adjust spacing between wheel fearing bracket and disk break.
Adjust Torque of Axel nut based upon Matcos installation instructions. Nut has to be tightened not loosened after rim stops spinning free. This is due to the type of bearing seals used.
Drill holes in axel to accommodate axel nut and carter pin.
Slightly enlarge holes in axel nut to accommodate larger carter pins supplied in kit.
