Back of Engine mount rubbed against lower Aux Fuel Pump platenut. Tried to reposition platenut but was unable to get enough clearance on aft side. Rotated fule pump aprox 10 degrees and drilled new mounting hole. Lower flange will will be secued with original bolt and lock nut on on aft side.. Original hole caped with stainless steel plug and will seal with fire wall sealent. Plumbing to fuel pump will need slight adjustment when remounted.
