Brief Description: Continued fitting Canopy frame to fuselage
Verified all clearances as per manual
Drilled roller tracks to fuselage deck.
Bolted first and last bolts of tracks to canopy deck. Front bolts required grinding notch in bottom flange of fuselage deck to get tools into channel to tighten bolts. Same situation as roll bar.
Match drilled front and rear of back slider to top skin and rib flanges.
