Drill bolt holes thru fire wall and structures behind fire wall. Due to the amount, thickness and types of materials (stainless steel, thick aluminum, structural steel) holes were drilled out progressively with last drill out thru actual engine mount. This provided a close tolerance match drill.
Made sure mount was straight and plumb to fuselage
