Brief Description: Provide isolation between fuel and brake lines
Plans call for foam insulation. Due to the way the lines have to be run it is not possible to use rigid foam. Used fiberglass instead. This was much easier to install, will provide better isolation, reduced vibration, and is fire resistant.
