Brief Description: Install Lower Wing Sking to Fuselage Screws
Install Lower Wing Skin to Fuselage Screws
Since incidence, plumb and sweep were good did not want to remove wing to drill and dimple / countersink for nut plate and screws that hold lower wing and fuselage skins together.
Instead used markings made before wings were attached (see blue layout lines on image 1) to match drill and attached with AN526C832R8 (Stainless steel Truss head Screws), AN960 #8 washers, and AN365-832A (Stop Nuts).
