Brief Description: Drilled out Inner seat ribs for Control Arm Access
Spoke to Vans regarding the amount of material removed, and Control arm banging into the rib. They said the amount of material to be removed will need to be set after control push rods are attached. Mentioned the possibility of adding doubler to outside of rib, like the access ribs. They said serveral builders had same issue and did add doublers. Ordered two access rib doublers and will cut inners rib like access ribs and rivet in doublers. This will also make installing and servicing control arm easier.
