Brief Description: Terminate and Fabricate ELT wiring
Terminate / solder cable conductors from GPS source / Power/ Common Ground. Create additonal ground wires from ELT and cable shield to be grounded aircraft from (as per wiring diagram from Stein).
Per recommendations from ELT manufacturer, fabricate RJ11 shielded teflon cables from ELT head to ELT. Cables provided by maunfacurer were unshielded telephone (Flat PVC ribbon cable). Add ground wires from cable shields to common ground.
