Brief Description: Install stainless steel primer lines
Primer lines were custom fabricated. Did not want to use copper. Fabricator welded AN800-2 primer cones to 1/4" stainless tubing to fit AN4022-1 spray nozzles.
Lines were run to Cyls 1,2 and 4 and terminated to T conector under fuel pump. Flex line was run to Selonoid valve and Gas Collator
Flex lines were wrong length. Sent back to fabricator to adjust.
