Neils Web Site
RV9A
Custom Mag / Start wring
Custom Mag / Start wiring
Terminated Switch side of P-leads
Verified continunity of P-leads and grounds.
Tested start wiring. Did not work, found broken leads on key switch - repaired.
Start start wiring will only work if - Key switch enabed, Left mag on, Right mag off, start button pressed.
Verified start contactor works.
Verified power to stater when above condtions met.
EX-3 Home
RV9A Home
3355
456
DAR and Technical Co
Delivery & Invenory
306
Finish
186
758
508
700
460
