Neils Web Site
RV9A
Install high apmerage wiring
Reinstall battery box
Install plate nuts thru firewall for negative battery post and engine block ground
Install negative ground strap from battery post to fire wall
Install wiring from positive battery post to starter relay
Install wire from starter relay to starter
Install clamps and clamp extension using oil pan bolts to secure starter wire.
Install ground cable from engine block to firewall.
EX-3 Home
RV9A Home
3363
456
DAR and Technical Co
Delivery & Invenory
306
Finish
186
765
509
700
460
