Neils Web Site
RV9A
Completed Carb heat assembly
This was a pain in the ass because it is poorly documented in plans, and what documentation there was split between the exhaust kit and airbox kit.
Heat Muff need repositioning to line up with inlet. This is the new style not shown in plans.
Lever is on opposite side of box because lever on plan side hit heat muff.
Riveted all part together.
Nails were use as float pins so the airbox would clear lower cowl during fitting. Clecos stuck out to far.
EX-3 Home
RV9A Home
3363
456
DAR and Technical Co
Delivery & Invenory
306
Finish
186
765
509
700
460
