Neils Web Site
RV9A
Assemble Carb support plate and filter brackets
Separate fuel sealed filter from plate and trimmed.
Cleaned off separation agent
Trimmed airbox top plate to fit around carb accelerator pump
(will require some additional sealant when filter is reinstalled)
Match drilled plate to filter brackets and airbox top plate
Debured all parts.
Drilled filter brackets for nut plates
Dimpled filter brackets and riveted nut plates
Tightened and safety wired support plat attach bolts.
EX-3 Home
RV9A Home
3363
456
DAR and Technical Co
Delivery & Invenory
306
Finish
186
765
509
700
460
