Neils Web Site
RV9A
Fit Air Box Filter
Fit Air Box Filter
Temporarily bolt mount plate to carb. Bolts need to be safety wired to carb on final assembly
Fabricate 6 retainer clips (not 5 as incorrectly as specified in manual)
Cleco retainer clips to mount plate
Cut filter so it fits around carb accelerator pump, and lays flat on mount platel
Coat mount plate an carb accelerator pump with release agent (Partall #10) so filter can be removed
Coat filter gasket and carb accelerator pump with high temp permatex gasket seal.
Put filter on carb and mount plate, weigh down, and let dry.
EX-3 Home
RV9A Home
3363
456
DAR and Technical Co
Delivery & Invenory
306
Finish
186
765
509
700
460
