Used the ignition bulkhead fitting as a drill template to the baffle. Used a 3/4" unibit to drill out center area then finish out with with a file. Made up hot lead connections to coils and checked for proper fiing per LSE manual.
Use of bulkhead fitting to matchdrill holes in baffle
