Brief Description: Front Baffle Inlet ramps Trim layout
The forward baffle inlet ramps are WAY too long from Van's and must eventually be trimmed to be flush with the cowl inlets. With bottom cowl in place, layed out first trim lines. It was NOT easy as the baffles are so oversized. After this point, I only fit up one side at a time as it was too difficult to fight both sides at the same time.
"Raw" Baffles fitted to engine. Now for the trimming
