Mikes RV-9A Web Site
Date: 11-11-2007
Number of Hours: 1.50
Brief Description: Must be Friday the 13th!! It CRACKED!!
OMG…. Almost done and my tip-up cracked!!
Conditions preceding the event: Canopy holes were countersunk and drilled out with a 5/32” plexiglass drill bit. Canopy was held in place on each side of the frame with three #6 screws and outside skirts were cleco’d in place. Using a #27 standard drill bit, commenced match drilling from the inside through the tip-up canopy frame/canopy assy into the outside skirts.
All went well exactly as planned.
The event: After removing the skirt cleco’s and the 3 screws on each side, I reinstalled the skirts with clecos so the last 3 holes on each side could be match drilled. When it was all said and done, I found the forward most hole on the left side had a huge crack in the canopy, coming out of the hole!!!!!!! I nearly had a heart attack on the spot!!!!!!! You know… one of “those” moments when you experience utter denial. NO NO NO… this can’t be happening.!!!!
The Cause: After performing a through investigation and root cause analysis, it was concluded the builder (me) is a flaming bloody idiot!!
For some reason, the forward most hole had not been drilled out from 1/8” to 5/32” with the plexiglass drill, nor had it been countersunk. Some how, I missed “finishing” that hole. When I match drilled, using the #27 bit, it caused a stress riser in the original 1/8” hole and off went the crack about 15 minutes later!!
The Punishment: I could have lived with an “accident”, but this was my doing… or should I say “undoing”!! Tonight will be the flogging with a cat-of-nine-tails… followed by a soak in the hot tub to calm down. Holy mackerel…. I’ve read about not drilling plexiglass with standard twist drills… now I stand before my peers to attest, NEVER EVER let a non-plexiglass drill bit remove so much as a sliver of plexiglass!!
How’s that old flying adage go… something to the effect: Building in itself is not inherently dangerous, but it is terribly unforgiving of any carelessness, incapacity or neglect.
Now… to start over… I'll sit this canopy over
Skirt in place ready for match drilling
The Damn crack!!
