Mikes RV-9A Web Site
Date:  2-9-2010
Brief Description:  Aux fuel tank feed line support completed
Completed fabrication and mounting of the Aux Fuel Tank feed line support bracket. This line needs to be held in place and out of the way of the flap control bar, when an aux tank is not installed to support the fuel line.
Discovered the fire extinguisher upper support rivnut touched the flap control bar when cycled up and down. The back of the rivnut is just long enough to barely touch the flap bar. Drilled out the upper rivnut and replaced with a screw and friction nut. No longer interferes with flap arm movement.
Aux Fuel tank feed line, which needs support when the tanks are not installed
Completed mounting of aux fuel line bracket and mounting of cover
Other side of flap control housing
