Mounted right aileron and push tubes. Ran into tube clearance problems at the rear spar. Plan to seal weld the rodend to the tube instead of rivets. Removed both ailerons and all push tubes. Ran pitot tube through ribs, cut to length and bent outboard ends. Placed both outboard bottom skins to wings in prep for match drilling.
Aileron push rod needs more clearance for rivet. Decided to seal weld these joints instead
