John Stahr brought the fuselage to KUAO (Aurora, OR) and with help of Dan Forney, we off loaded it and put the wings on. I cold soaked the NAS bolts and used lubriplate grease, then used the rivet gun to drive all bolts through the spars. HOWEVER, the bottom large bolts don't leave enough space between the spar and gear leg mounts to insert the nuts! That means these 4 bolts will have to be pulled back enough to drop the nuts in place. I'm not sure HOW to backout these extremely tight fitting bolts!! ARRRGGGGGGGGGGGGG
Dan Forney helping unload from John Stahrs trailer
Dan Forney helping drive home those pesky wing bolts
