Using ProSeal, glued in trailing edge wedge pieces for rudder and both elevators. Cleco'd edges together witih Al angles.Glued in trim tab foam wedge ribs.Wow, this ProSeal is the most vial stuff I've ever worked with..... unGodly sticky to everything you touch!! What a mess!!!!!!
Rudder & both elevator trailing edges closed out with ProSeal
