Completed riveting nutplates to cowl louvers and cover plugs. Reviewed &revised some of the FWF wire routing and tie-offs. Function tested with heat gun all 4 EGT/CHT probes, oil and air temp probes. All work as expected. Verfied EFIS calculated density altitude changed with changing air temp indication. Added Throttle/Prop/Mix control function labels.
