Brief Description: Bled brake lines, ran manifold pressure line
Ran Manifold Pressure line between firewall bulkhead fitting to GRT MP converter and LSE Ignition module. Back bled brakes to reservoir using DOT 5 silicon brake fluid
Manifold pressure (yellow tubing) line and back filled brake lines to reservoir (purple)
