Moved LSE Ignition computer from bolted to the upper right inside of firewall to the center of the firewall. The computer was screwed to the SS firewall, but became obvious I would never be able to remove it in case of maintenance. So moved it to center of firewall and secured with a hinge and single screw through firewall, with screw head on engine side. That way, with removal of single screw and pulling the hinge pin, the computer could be "easily" removed and replaced. At least that's the theory.
