Mikes RV-9A Web Site
Date:  8-5-2008
Brief Description:  Fuel Inj body - Van's fuel lines
Removed fuel injector body and installed control cable mounting bracket. Reinstalled injector body and attempted to route the fuel line from the mechanical fuel pp to the injector body. Because Van's FWF kit only supports Horiz draft engines (and my engine model is vertical draft) I'm having trouble with hose lengths from the kit not being adequate. I could not get Van's hose to route from A to B without it interfering with where the throttle cable will have to run.
So I had to take the hose off and work with "Plan B"
Throttle/Mixture bracket mounted
Van's fuel line from Inj body
Van's fuel line into mech fuel pp.
