Brief Description: Fuel tank bracket drilling, misc.
Using a vice and a big mallet, was able to bend the angle to match the wing to fuselage curvature. Then matchdrilled to fuselage and to the fuel tank bracket. This is tedious in ensuring alignments and blind drilling from inside the fuselage into the bracket flange foot. But it came out good.
Also set nose gear kickout force of 22 lbs. then drilled the cotter pin holes in the axel.
