I purchased an alternate canopy latch system that is flush with the fuselage skin, rather than the Van's setup. It took some "engineering thinking" as to how to translate these thick latches to the layout in the Van's plans.
Latches located at bottom of plans slot
Visualizing latch layout on plans set.
Brackets have to me mounted on the angles just so, so they will be flush to the skin
