Started with a rigid wire to create a bending template. Slip the fitting sleeve on the straight tubing before staring to bend, then flared the tubing end that mates to the 90 deg sidewall fitting. Using a large dia plastic wheel from a sliding door as a bending tool, start bending where the rudder cable has to go. This "little" wheel works great!
