Brief Description: Rudder pedal & center brace installation
Drilled 3 sets of rudder pedal spacing holes. Cut notches, lightening holes and rivet holes in center bracket. Then match drilled to firewall. Then matched drilled the nylon center block to the center bracket for each of the three rudder pedal positions.Next operation.... elevator bellcrank.
Use of scrap sheet Al to protect fuselage skin from drill chuck
Rudder pedal center bracket fabricated
Center bracket clampted to rudder pedal nylon block for match drilling to bracket
