Brief Description: 7th flight - (3) Rudder trim evaluation
Using segments of wood triangles made from door shim stock, made 3 flights at 3,000 ft and 70% power to determine yaw trim effects with different lengths of wedge trim. Need to make one or two more evaluation flights to settle on final trim block length.
Flight test path
Segments of wood wedges
Plastic wedge from Avery Tools, to be test flown next
