1. Completed fabrication of rudder pedal links, painted same & attached pedals to cables. 2. Bled brakes, pumped pedals, pressurized system with parking brake and found to be leak free. 3. Filled Rt wing with fuel and used fuel pp and tygon hose to transfer fuel to Lt wing. Tried to calibrate GRT EIS-4000 level transmitters, but didn't work out correctly. Ummm.... perhaps it was my "mental math".... will use calculator next go around to derive scale and offset numbers.
