Completed wiring between outboard wing to tip fairing. Verified Landing lite, Nav lite and Strobe light works. YEA!
Set aileron alignment jig and verified TE matches flap position when flap in full up. Need to make up Transponder coax connectors, then can screw on wing tip.
Right wing tip wiring connections completed. Left leads long so easy to remove tip fairing.
