Mikes RV-9A Web Site
RV-9A
Mounted ailerons,flaps & HS
Hung ailerons and flaps, but no spacing washers yet, until rigging alignment is completed. I'm only putting those washers in ONCE. Need to rivet the ID tag on the fuse under the HS before the vert stab can be mounted.
Flaps full down
Put Dan to work tightening HS stab bolts
Long-EZ Home
RV-9A Home
1787
Assembly & Preflight
Assyembly & Prefligh
264
Baggage Aux Fuel Tk
138
Delivery
Documentation
Electrical Dwgs
144
262
Flight Test
382
Maint-Squawks
Paint-Finishing
43
202
112
