Dan's Web Site
Date:  10-5-2009
Number of Hours:  0.25
Brief Description:  Fit FAB Mount Plate to Carb
After replacing the drain plug the FAB mount plate almost fit flush against the carb. I had to use a sanding drum in my dremel tool to sand out a small recess for that large nut just forward of the accellerator pump to get it to sit perfectly flush against the carb.
FAB mount plate now sits flush against the carb
FAB mount plate clecoed to carb
