Dan's Web Site
Date:  10-6-2009
Brief Description:  Trim, Punch, Drill, Rivet Final Airseal Strips - F
I received another roll of airseal material from Wag Aero today so I decided to finish that up today. It took a bit of trial and error before finding a combination of cuts/strips that sealed up nicely against the top cowl while still making the bends around the corners. I used screws wherever strips overlapped and rivets everywhere else. The only thing left to do on the baffles is to pull the cylinder wraps tight against the cylinder fins with either some type of threaded rod or safety wire. Other than that the baffles are complete!
Left front airseal strips riveted to baffles
Right front airseal strips riveted to baffles
Airseal strips complete.
