Brief Description: Replace Pop Rivets with Screws - Left Front
I decided to replace all of the pop rivets holding the baffle material to the baffles with 6R7 screws, washers, and metal lock nuts since virtually all of the mandrels pulled out from the centers of the pop rivets and left holes that would need to be sealed somehow. Rather than using RTV I decided to go with screws instead. So,,,I removed the front left baffle, drilled out all of the pop rivets and reinstalled the baffle material with screws instead.
Left front baffle removed
Left front baffle with pop rivets drilled out and replaced with screws
