Brief Description: Final Rivet Back Baffles - Cyl Fin Wrap Plates
Next I riveted the doubler plates onto the flanges of the cyclinder fin wraps on the two back baffles. I also riveted the cylindrical flange for the cabin heat SCAT tubing along with a screen to back of the right baffle and sealed around the edges with high temperature RTV. I also had to seal one of the mounting holes for the oil cooler that couldn't be used because the bolt would interfere with cylinder cooling fins.
Right aft baffle - doublers riveted to flanges of cyl fin wraps and SCAT flange riveted and sealed
Screen riveted over SCAT flange for cabin heat
Left aft baffle - doublers riveted to flanges of cyl fin wraps; Extra oil cooler mounting hole sealed
