Brief Description: Match Drill Parts 4 & 5 & Reinforcement Components
Once I had a couple of alignment holes drilled through all of the corner components I removed parts 4 and 5 from the engine, clecoed everything back together on the workbench and then match drilled all of the other holes.
Parts 4 & 5, along with oil cooler doubler plate, spacer, and reinforcement angle match drilled
