Brief Description: Install Paper Clips on Top Edges of Baffles
Next I removed the upper cowl and installed plastic coated paper clips onto the top edges of the baffles. Then I reinstalled the upper cowl which pushed the paper clips down to form a perfect contour of where the upper cowl should be.
Plastic coated paper clips installed along top edges of the baffles
Upper cowl reinstalled to create a paper clip contour
