Once the mounting spacer was riveted to part 6 I installed this baffle on the engine. A temporary bolt was inserted to make sure everything lined up properly.
Forward view of part 6 mounting bolt - spacer is on the aft side
Here you can see how the spacer comes into play between part 6 and the engine block
