Brief Description: Mark Front of Left Side Baffle for Trimming
The top cowl is fitting pretty well at this point, especially on the right side. The left side still has a problem but not with the top edges of the front bulkhead. Reaching up in through the inlet there is a small gap now between the top edge of the left front bulkhead and the upper cowl. Plus the eyelet's on the left side hinges are not aligning. The top cowl is a little too far forward and I can't push it back. It turns out that the front edge of the left side baffle - part 3 is preventing the top cowl from moving aft so I marked it to be trimmed next.
Right side mating up pretty well - small gap because of the problem on left side
Left side isn't matching up but this is more of a front/back misalignment rather than an up/down issue
And here's the problem - the front of the left side baffle (part 3) sticks out too far forward - mark
