Brief Description: 3 Iterations of Trimming Top Edges of Baffles
I did 3 iterations of marking the top edges of the baffles to be trimmed, taking everything apart, trimming and deburring the baffles, reinstalling everything to check the fit again and marking for the next iteration. The height and contour of the front baffles are looking good. I still have quite a bit of trimming to do on the aft baffles.
I am VERY worried that I mounted the oil cooler too high on the aft left corner. I have a little trimming room to work with but if I have too far to go and the oil cooler ends up hitting the top cowl, I'll have to remake the aft left corner baffles and lower the oil cooler.
Initial trimming of left aft corner - worried about oil cooler being too high and hitting cowl
Getting there - left side getting closer, especially up front
Getting there - right side getting closer, especially up front
