Dan's Web Site
Date: 9-14-2008
Number of Hours: 1.50
Brief Description: Drill / Debur Oil Cooler Baffle Parts (4&5)
Once the holes for the oil cooler mounting bolts were drilled, all of the remaining spacers, brackets, and reinforcement plates for the aft left corner baffles (parts 4&5) were drilled and deburred.
One note on the reinforcement angle that runs diagonal on the side baffle from the mounting screw on the cylinder head up to the top of the corner reinforcement angle for the oil cooler,,,rather than trying to bend a joggle into the diagonal angle to fit over the corner angle, I added a 0.040 spacer plate to raise the angle up to fit flush over the corner angle. The spacer plate is shown in picture 3 below and has the cutout for the cylinder head cover.
Oil cooler reinforcement plate drilled to parts 4&5
Corner reinforcement angle drilled to parts 4&5 along with the 0.063 spacer
All brackets, reinforcement plates, spacers, etc for baffle parts 4&5 drilled and deburred
