Brief Description: Reinstall Baffles and Oil Cooler
Today I reinstalled all of the baffles on the engine and then bolted the oil cooler back onto the left aft baffle. The hex support rod is also temporarily in place. This significantly reduces the amount of movement that is possible on the left aft baffle that has the oil cooler mounted to it. Hopefully this will prevent the baffle from cracking from the vibration.
