Brief Description: Sand Right Inlet Ramp; Fiberglass Over Rivet Holes
Today I sanded the micro on the right inlet ramp. Both ramps are nice and smooth now. Then I sanded the inside of the top cowl along the aft edge that joins up with the firewall. I needed to cover all of the rivet holes that were drilled for the old hinge. Once the fiberglass dries on the inside I'll flip the cowl over and add micro to all of the rivet holes and then cover the outside with a strip of fiberglass as well. Then I'll be ready to drill for the new camloc's.
Right inlet ramp and aft inside edge of top cowl sanded and one layer of fiberglass and peel ply added
