Dan's Web Site
Date:  11-2-2007
Number of Hours:  0.50
Brief Description:  Drill Sides of Lower Cowl to Hinges
Prior to installing the lower cowl on this most recent iteration I duct taped the side hinges to prevent them from rotating while drilling the cowl to the sides. This worked out very well. Once again I used the corresponding rivet pattern on the fuselage side of the hinges to drill the cowl hinges. I started at the bottom and worked up. The lower cowl is now fully drilled and clecoed to the firewall hinges!
Left side of lower cowl drilled and clecoed to hinge
Right side of lower cowl drilled and clecoed to hinge
