Brief Description: Straighten #9 Pin on J1 GMA-340 Connector
Today I was going to replace the bent #9 pin on the GMA-340 J1 connector but these are the smaller high-density pins and I don't have a crimper that will handle these. Fortunately I was able to straighten the pin with some needle nose pliers. Once the pin was straightened I reinstalled the J1 connector onto the GMA-340 backplate and then carefully slid the audio panel back into its tray. I won't know if this truly fixes the problem until I get my SL40 back from Matt.
Pin #9 on J1 connector straightened and cable screwed to backplate.
