Dan's Web Site
Date:  4-1-2007
Number of Hours:  1.00
Brief Description:  Bolt Throttle and Mixture Cable Ends to Carburetor
Once the throttle and mixture cables were routed through the firewall and through the mounting bracket that is bolted between the carburetor and sump that Van's supplied, both cables were bolted to their respective carburetor control arms using all of the special spacers and washers called for in the plans,
Throttle and mixture cables bolted to carburetor
