Brief Description: Install Carburetor and Control Bracket
Next I removed the cover plate that AeroSport Power placed over the sump where the carburetor bolts on and sandwiched the engine control bracket between two gaskets and the carburetor and bolted the assembly to the sump. I then clecoed the cover plate over the carburetor intake to keep junk from getting in the carb.
The plans say to torque the carburetor bolts again the next morning since they compress over time.
Engine control bracket, gaskets, and carb bolted to sump and cover plate clecoed to carb intake
