Dan's Web Site
Date:  5-28-2006
Number of Hours:  1.50
Brief Description:  Drill Air Gizmo Tray to Rails for Garmin 396 GPS
Today I drilled the final tray to the support rails. Once again, the Air Gizmo tray is a bit smaller than the other Garmin trays. So,,,I have two radios that are 6.25" (GTX327 and GMA340) and two that are 6.30" (SL40 and 396 Air Gizmo). I used washers on the right side to fill the gaps between the trays and rails. I need to fill the gaps between the Bezel's of the radios on the right side and the panel itself. I'm not sure how I'll do this yet. I also have a gap on the top above the Air Gizmo tray for the 396 handheld GPS.Once all of the trays were drilled and bolted to the support rails I temporarily installed all of the radios and snapped this picture.
Air Gizmo tray drilled and bolted to the support rails. This will hold the Garmin 396 GPS
All radio trays installed and radio's temporarily in their trays
